seanlee75
Jan 07, 2019Aspirant
RBR50, RBS50, AP, Ethernet Backhaul - Advice please?
Hi everyone,
My first post on the Netgear community - please forgive me for any wrongs that I commit!
I've spent hours reading posts here, as well as hours trying to make the RBR50+RBS50 wor...
Jan 07, 2019Guru - Experienced User
You can use current FW for the system. It should be using v210 if your keeping the system up to date.
You can review this for setting up eithernet back haul:
I would do this while in the same room as the router for ease of initial setup first. I would recommend setting up a satellite 1 at a time, connect it wireless first. Then connect the LAN cable between the satellite and router. Wait up to 5 minutes for the top of the satellite to turn BLUE. Do a IP address reservation for the satellite ON the router. Save and apply the reservation. Turn off and place in remote location.
Do this process for each satellite you are adding.
You should be good to connect to a unmanaged switch in between the satellies and base AP.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. I would check mark this feature before you begin to add satellites. If you seem to run into problems, come back to this setting and remove the check mark.
seanlee75
Thank you so much for the input - have you experienced a reliable outcome using the Orbi with ethernet backhaul?
- FURRYe38Jan 07, 2019Guru - Experienced User
I have along with my friends I set up last summer. His has one satellite still using it on wired back haul. Zero issues.
Couple of caveats, if you have a need for a networks switch, non managed, non green ethernet switches are recommended. If you need to use a managed switch, disable IGMP protocols on this switch. Orbi and this protocol doesn't seem to work well together. :smileyfrustrated:
I have a few switches on my network. Two in between my router and satellite. Video streams from one room that connects to the satellites 5Ghz in the office next room over. Streams thru to the DISH Hopper just fine in this configuration.
- seanlee75Jan 07, 2019Aspirant
Hmm. I was proposing to use a HP 1420 8-port switch just for the Orbi but that switch is a green switch. May I have to reconsider what switch to use - most are green these days.
You can find non green switches still. HP still has some I think. NG and D-Link does. I use D-Link DGS-105 and 108s. My man switch is a HP 1400 24 port going on about ten years old now. Solid switch. NG GS series I believe are standard switches as well. Might find them on Amazon. I find both on Amazon.
