nmoncivais's avatar
nmoncivais
Follower
May 07, 2020
Rbr50 replacement
So I received a replacement router due to my router randomly rebooting itself daily. What’s the best/easiest way to set up the new router-through the app as a “new set up”?
  • plemans's avatar
    I would do it as a new setup.
    I prefer to do the setups using the browser hardwired in. It tends to go faster in my experience.
  • michaelkenward's avatar
    michaelkenward
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    Find the setup guide and follow that.
