Rudders64
Jan 28, 2019Tutor
RBR50 Ring flashing white continuously
The RBR50 appears to have broken itself during an update two days ago. Router ring continuously flashing white, no WiFi network, can't access the router via cable, factory resets unsuccesful! Just a dead brick flashing mournfully on the desk and two useless pink glowing satellites!
My router is setup as an AP to share a mesh through a second building. It connects via cable to the primary router which is a Nighthawk X6. This has been working nicely for about 10 months but is now useless.
The flashing does cease after a long period of time but there is no activity from Orbi.
I would love to provide the firmware version but I can't access the router to find out.
This appears to be a similar proble to on that occured 18 months ago to satellites. Ther emay have been other instances as well but I haven't found those threads. Other than physically replacing the RBR50 is there a solution?
Sort By
Did you press in the back reset button until the top LED on the router turned Amber, then let go and see if you can access the orbi's web page at 192.168.1.1? See if your PC get an IP address from the router after this...If not, then the router is probably broke.
You can try this with the Orbi router:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Try the TFTP client already built into Windows...
- UlairiLuminary
I have exactly the same thing going on. After a power cut last week the router did not come back online and is continully flashing white on top. The power LED on the rear is flashing red. The router will not reset. I cannot access it via www.orbilogin.com or http://192.168.1.1 . The Orbi User Manual (page 16) says that flashing white indicates that the router is rebooting and that the flashing red power LED means that the firmware is corrupted.
There have been other reports of this occuring in messages on this forum, albeit manily for RBS50 Satelitte problems rather than the RBS50 router. While some people have reported success with manually reloading the firmware, others have not been able to restore the Orbi. The official 'solution' per this thread is to RMA the Orbi (albeit for a RBS50 satellite, rather than the router).
I was unwilling to flash the firmware while the router was still under warranty, so I have returned it for replacement under warranty.
The really annoying thing was the woeful support from Netgear. Twice they arranged a support call and on both occassions I waited by the phone for two hours with no call from them either time. That was despite Netgear phoning me after the first missed call, apologizing and assuring me that they would honor the second time slot. Hence the warranty return - I'm not prepared to muck around any longer.
Next time try a manual FW update and then ERASE the router and setup from scratch and walk thru the setup wizard.
Its ok to do FW updates while the system is under warranty. You won't void the warranty by doing any FW updates. You'd only void if you applied non supported 3rd party FW. However there isnt' any currently for Orbi.
Thanks to both of you for the info.
The router eventually booted through the flashing white phase to a steady magenta ring (never a red power LED that I saw). The magenta is now out and I can see a WiFi network from it. I haven't flashed a FW update as I haven't been able to see it through an Ethernet cable. I now have access through the ios app. Trouble is that it has never been set up for my isp as it has always been an AP. The ios app doesn't seem to be able to reset it back to an AP and I still can't get to it through a cable. Fun times.
I can now say that it is running FW 2.2.1.210 though.
