paulc1978's avatar
paulc1978
RBR50 satellite devices
I have the Orbi RBR50 (in the lounge fairly close to the garden satellite) with 2 satellites, one in the garden summerhouse (hard wired) and one upstairs. Is it possible to set any devices in the garden summerhouse to connect only to the garden satellite. On occasions they try to connect to the main router in the lounge as its not too far away. The problem with this is that the device (Sonos or Firestick) drops when switching and then drops again when switching back. Very frustrating and am hoping there is a way I can dedicate these devices to connect to the garden satellite only which is a very good connection to the main router.
  • plemans's avatar
    No. there isn't a way to set them to a specific satellite. They roam based off their own roaming protocol.
    If you have 2 much coverage through, it can cause more frequent roaming. You could try turning your broadcast power from 100% down to 75% and see if it helps.
    • paulc1978's avatar
      paulc1978
      Hiya
      Ok, thanks for your suggestions. I will try this and see if it works
