DanTyler's avatar
DanTyler
RBR50 Satellite issue
Hi all
I am having a lot of issues with connectivity of one of my satellites. I want it to connect to the main RBR50 router but instead it connects to my other RBS50 which then causes it to go amber onthe network map visual on the app. Can i force it to connect to RBR50?
Thanks
Dan
  • Please disable "Daisy Chain" under advanced wireless settings, so all Satellites will be then forced to connect only to the Router.
    • DanTyler's avatar
      DanTyler
      Thanks for the response. Where can i find advanced settings?
      • ekhalil's avatar
        ekhalil
        Master
        You need to use a browser on your computer to navigate to orbilogin.com to get the Orbi web GUI.
        The Advanced Wireless Settings can be found as in the attached.
