Anonymous's avatar
Anonymous
Jan 29, 2020
RBR50: Satellite not connecting - I can see the Satellite listed, but ...
The RBR50 router seems to running perfectly.  The latest firmware has been installed ( V2.5.1.8).  The Attached Devices screen shows the satellite (RBS50), but IP Address, Connection Type, and Backhaul Status are blank.  When I try to Sync (many times), it fails to do so.  IF I connect the router to the satellite, the IP Address (192.168.1.16) appears, The Connection Type is "wired", and the Backhaul State is "good".  I've try to sync them and again it fails.  Does anyone have ideas on how to sync the Router and the Satellite?  Thanks for your help!!!!!
1 Reply
  • FURRYe38's avatar
    And you updated both RBR and RBS FW versions?
    Are you getting any top ring LED indication on the RBS during it's sync process?
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Armor, Circle, Daisy Chain (Needs to be disabled for wire connected RBS), Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
