PaulBrassington
Jul 26, 2018Aspirant
Rbr50 satellite to satellite
Just bought the RBR50 router and satellite but our cabin at the end of the garden is too far away. So I have bought a second satellite, please advise how to connect the second satellite to the first ...
Jul 26, 2018Guru - Experienced User
Should be able to enable Daisy Chain on the router and this should set up the satellites to piggy back of one another...
- PfreddJul 27, 2018Guide
Where is the Daisy Chain setting?
I can't find it on my CBR40
- PaulBrassingtonJul 27, 2018Aspirant
Hi All,
This worked for me:
http://orbilogin.net on my PC, then Advanced tab, Advanced Set Up, Wireless Setup then click Enable Daisy Chain Topology
Connect the first satellite to the Router
Put the second satellite in line with both (a straight line between all three , this stops the second satellite to connect to the router) then turn the second one on, click the first satellite sync button and then the second satellite sync button.
Open the app on my phone and see the network map to ensure they are in line.
Hope this helps you all.
There is no "Daisy Chain" option on my CBR40. It has the latest firmware.
Here is a screenshot of the Advanced Wireless Setup screen:
