Retired_Member
Jul 19, 2025RBR50 satellite
Hi All I have an RBR50 router + RBS50 satellite. Works well, but I need another satellite. I know you can pair RBS20 and RBS40 with RBR50, but will that compromise the overall backhaul speed betwe...
Jul 21, 2025Guru - Experienced User
IF you can hardwire in a RBS40, it'll perform at the same speed as the RBS50 as the wired backhaul will have lower latency and be faster. Technically the RBS50's wireless backhaul is faster but it decreases quickly with distance/obstruction/interference. I"ve always wired them in when possible.
