HuhWhoKnew
Aug 13, 2019Aspirant
RBR50 Set Up, Frequency Selection
Hi All,
New to Orbi, just switched from Nighthawk X4S AC2600. I have ~ 1098 sf, 2 story. Router on 1st floor; satellite 1 - 1st floor ~ 30 ft away with kitchen cabinet wall between; satellite 2 - 2nd floor ~ 30 ft with ceiling/floor between.
Orbi Firmware is 2.3.5.30
Modem is Arris Surfboard SB6190 (mine)
ISP Spectrum
Speed 200+
Devices: Can I designate what satellite they use? Frequency they use? I have 3 devices on 2nd floor not using sat 2 for some reason. Printer and sleep number bed on 2.4, laptop on 5. They are directly over sat 1 and separated by 2 walls from sat 2.
How can I improve WiFi speed? Basically getting 160 avg when sitting between router and sat 1. It waffles alot between 160 and 90+. Not sure if it is interference of ISP.
You might want to try lowering the power output of the RBR from 100% to say 50% as a test. Under Advanced Tab/Advanced Settings/Wireless Settings
It's up to the client devices to connect to the freqency they pick and choose to best suitable.
HuhWhoKnew wrote:Hi All,
Modem is Arris Surfboard SB6190 (mine) > There are known issues with this model modem FYI.
ISP Spectrum
Speed 200+
Devices: Can I designate what satellite they use? No. Frequency they use? No.I have 3 devices on 2nd floor not using sat 2 for some reason. Printer and sleep number bed on 2.4, laptop on 5. They are directly over sat 1 and separated by 2 walls from sat 2.
What wireless device are you using to speed test with?
What speed results do you get with a wired PC connected to the RBR?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- HuhWhoKnewAspirant
What wireless device are you using to speed test with? iPad 6th Gen using Ookla
What speed results do you get with a wired PC connected to the RBR? 200+ I was pretty much able to match wired speed when I had the AC2600 hooked up but I was only getting (paying) 55 mbps clocking 70+.
Any Wifi Neighbors near by? If so, how many? 8+, I live in a vertical condo so have 2 common walls.
Set 20/40Mhz Coexistence to 40Mhz only I only have Enable/Disable Option. When I Disable it does not provide a way to set to 20 or 40
Armor I cannot find where to disable
HuhWhoKnew wrote:What wireless device are you using to speed test with? iPad 6th Gen using Ookla
Could be a reason for some wifi performances. Having many other wifi neighbors can be problematic. Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. You might want to try lowering the power output of the RBR from 100% to say 50% as a test. Under Advanced Tab/Advanced Settings/Wireless Settings
Set 20/40Mhz Coexistence to 40Mhz only I only have Enable/Disable Option. When I Disable it does not provide a way to set to 20 or 40. When you uncheck the 20/40Mhz box, this sets it to 40Mhz only.
Try under access controls? You may need to factory reset the RBR and setup from scratch and this time, don't enable Armor during the setup wizard process.
