Fitrich
Jan 06, 2024Follower
RBR50: Setup with Verizon G3100 router
I had my Orbi RBR50 with 1 satellite setup with the Verizon G3100 router. A power outage in my home caused a wifi connection problem and now I can't get the RBR50 to work. Because it stopped working,...
Jan 06, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
Logging into the RBRs web page at 192.168.1.1 or orbilogin.net with a browser can get you FW information and setup of the RBR. You may need help from the ISP with the ISP router to configure it if needed.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
FYI:
