NvdM
Nov 29, 2025Aspirant
RBR50 signal lost multiple times during the day when having teams calls
I have a RBR50 router connecting to two sattelites. One on each floor. On the 1st floor the connecting is lost several times during the day. On the 2nd floor the issue is the same. How can I impr...
NvdM
It is happening for a long time already. I am not so technical. What do you mean?
Nov 29, 2025Guru - Experienced User
NvdM wrote:It is happening for a long time already.
Months? Years? Since you first installed it?
NvdM wrote:I am not so technical. What do you mean?
Log into the admin web ui, and then click on the "attached devices" tile on the upper right.
You'll see the connected satellites at the top, and the far right column is "Backhaul Status". The "Connection Type" field is also relevant.
NvdM wrote:Wired devices don’t drop
Are any of these connected to the satellites? Or are they all connected to the router?
- NvdMNov 29, 2025Aspirant
Since it is installed but it seems to occur more and more recently.
Backhaul status is Good over all devices. Connection Type is 5G
StephenB wrote:
Are any of these connected to the satellites? Or are they all connected to the router?Also connected to the satellites. Like Philips Hue and Tado for home automation is connected to the sattelites.
- StephenBNov 29, 2025Guru - Experienced User
Sorry - I was referring to wired connections.
Do you have any of those connected to one of the satellite LAN ports?
Are the connections going to the main router also dropping?
You might need to connect in the same room as the router to determine this.
If you have a wired PC connected to the router, it would be useful to connect to the router web ui using that PC. Then see what the satellite backhaul status is.
Yes,
I have a beestation connected wired to the satellite. The connection is solid.
as we work on the 1st and 2nd floor the stateliness are the main issue. We don’t often work downstairs. Haven’t faced issues doing so
