NvdM
Nov 29, 2025Aspirant
RBR50 signal lost multiple times during the day when having teams calls
I have a RBR50 router connecting to two sattelites. One on each floor. On the 1st floor the connecting is lost several times during the day. On the 2nd floor the issue is the same. How can I impr...
NvdM
Yes,
I have a beestation connected wired to the satellite. The connection is solid.
as we work on the 1st and 2nd floor the stateliness are the main issue. We don’t often work downstairs. Haven’t faced issues doing so
Nov 29, 2025Guru - Experienced User
NvdM wrote:I have a beestation connected wired to the satellite. The connection is solid.
Interesting. If the backhaul between the satellites and the router were the problem, then we'd expect the beestation connection to drop too. And if this were a hardware issue, we'd expect it to only affect one of the satellites, and not both.
Can you try keeping one of the laptops connected to power? Adjust the power settings so the laptop doesn't sleep or hibernate when plugged in. Then see if the dropouts still happen on that PC.
Also - are you using a VPN when you are on Teams video calls?
- NvdMNov 30, 2025Aspirant
No VPN. I will work connected to the satellite for the coming week and experience if it’s connection drops.
