jboogie15
Feb 17, 2020Aspirant
RBR50 slow connection upstairs
Hey,
Wifi works perfectly downstairs and I'm getting the advertised 200mbps all throughout my first floor. However, upstairs the connection is slow and intermittent despite having two satellites in both corners of the second floor. The firmware is up to date, and I have tried changing the placements and location of the satelites. Additionally, the router is in a central location and according to my internet provider everything looks good on thier end. I would like to note though that this problem only started occuring a few weeks before christmas. Any suggestions are apprieciated!
Thanks!
- tomschmidtVirtuoso
jboogie15, if you are running v2.5.0.x firmware, and it was retracted by Netgear after many bugs and stability issues were found. NG disabled autoupdate in recent releases due to the issues that it has caused. I suggest manually upgrading your RBR50 and satellites to v2.5.1.8 if you are running v2.5.0.x firmware. It is available from https://www.netgear.com/suppzio fort/product/RBR50.aspx#download
- jboogie15Aspirant
tomschmidt I'm currently running firmware V2.3.5.30 on my router should I go ahead and manually update to V2.5.1.8.
v2.5.1.8 is good to upgrade. Solid and stable. Upgrade the RBS first if you have them, the the RBR lasty.
jboogie15 wrote:tomschmidt I'm currently running firmware V2.3.5.30 on my router should I go ahead and manually update to V2.5.1.8.
