PCOPPOLA5373
Apr 11, 2018Follower
RBR50 Speed Test Failing
Can no longer use the ORBI app on my iPhone to condust a speed test. This problem just started within a week. When I try I get: Connection Failed If the problem persists, try rebooting your router...
Apr 11, 2018Guru - Experienced User
- CatherineA949Apr 12, 2018GuideI’m having the same issue as several others. The last week my Orbi with 2 routers and one main are connected to my iPhone X. Can’t do a speed test- connection failed try again.. what can fix this?
- FURRYe38Apr 12, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Connection-Failure-on-Speed-Test/m-p/1550252#M28113
