PCOPPOLA5373
Apr 11, 2018Follower
RBR50 Speed Test Failing
Can no longer use the ORBI app on my iPhone to condust a speed test. This problem just started within a week. When I try I get: Connection Failed If the problem persists, try rebooting your router...
TVman
Apr 13, 2018Aspirant
My speed test is repeatedly failing. Re-booted, as suggested. No luck. Would like to have it restored.
- FURRYe38Apr 13, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Connection-Failure-on-Speed-Test/m-p/1550252#M28113
Run any speeds tests with a PC and a browser or the Ookla speedtest.net from a mobile phone until the Orbi app and any onboard router apps are fixed. NG is aware of the issue. This is a service issue with NG.
TVman wrote:My speed test is repeatedly failing. Re-booted, as suggested. No luck. Would like to have it restored.
- CatherineA949Apr 17, 2018GuideMy Speed test just worked today after being out for over a month! Anyone else’s working?!! Try it! Thanks! Someone was listening!
- KimlavorgnaApr 17, 2018InitiateYay.....mines working too...Finally !!!.
- CatherineA949Apr 17, 2018GuideTry it again, several peoples speed test are working now.
- BHHJRApr 17, 2018Tutor
Mine works now too.
- CatherineA949Apr 17, 2018GuideTry your speed test again on the Orbi, several others worked today!
- TreborNewob5Apr 21, 2018Guide
:smileyfrustrated:Hi, Mine was the same so I had email [email protected], only finding this after wading through months of old negative feedback and help requests from many Orbi users in the Play Store app feedback section.
Up to this point E mails to Netgear support never got a reply, phone calls to Netgear as my 3 months Free support had run out I would need to pay for the premium service!
So I then tried the community and that was as bad no constructive help was forth comming.
Then I had a reply from the above email at app support who told me that they knew about the issue and with Ookla wee working to fix it ASAP.
And about 10 days later I saw the online chatter saying try Orbi it's fixed and for me it was.
So if yours is not working the only thing I would say try is remove Orbi reboot your phone then re install if thatstill fails try the above e mail for App support give them as much info as you can and cross everything and hope you get the same Guy as me who did give a Dam?:)
Netgrear has great products but the worst Support of any Global company I have ever delt with.
Good luck let me know how you get on?
- CatherineA949Apr 21, 2018GuideTry it again, speed test has been fixed for the most part.
