Thomasjames
Jun 06, 2020Follower
RBR50 still on 2.3.5.30 firmware
Hey I have had the RBR50 for awhile now and haven’t tried updating the firmware for a good while. The last time I tried to do it, it was such a pain and internet kept dropping out. I finally stuck wit...
Jun 07, 2020Guru - Experienced User
For those that want to update, if you don't see v16 as a notfication on your Orbi system, you can manually download the FW files and apply them your self thru the RBS and RBRs web page:
Again, for those who want to upgrade. v16 is working well for me on my RBK50 in AP mode.
If yours is working well, then keep whats loaded.
Enjoy.
Thomasjames wrote:
Hey I have had the RBR50 for awhile now and haven’t tried updating the firmware for a good while. The last time I tried to do it, it was such a pain and internet kept dropping out. I finally stuck with version 2.3.5.30 and everything seems to be working fine. My question is, am I missing anything performance wise or anything else from the current firmware that would give me a reason on why I should attempt to update? I usually go by the general rule of “if it ain’t broke don’t try to fix it”
Thanks for any suggestions.
