Ruze69's avatar
Ruze69
RBR50 (US Router w/3 Indoor Satellites Online) & RBS50Y Outdoor Satellite) will not Sync
Have a RBR50 + 3 Satellies Online and up for over 6 months.
Adding a RBS50Y Outdoor Satellite.
Syncing to Router unsuccessful. Even when located within the same room during Sync Process.
Factory resets, etc without success on the RBS50Y. Login on Router and all appears to be functioning for the rest of the system.
Please Advise!
RBR50 Router
3 - RBS50 Satellies
1 - RBS50Y Outdoor Satellite (unable to sync)
  • Ruze69's avatar
    Ruze69
    Sep 15, 2018
    Thank You for the reply.
    I keep my RBR50 Firmware "Auto" updated in these times. But, I was unable to access the RBS50Y unit without a Ethernet connection.
    I did find another obscure note while searching. Coincidence or not....
    It recommended Multiple Power Button Cycling after a 60+ second reset.
    It worked.... That is coincidence or Top Secret stuff! Lol!
    The unit was used to replace a standard Satellite and is awesome! Highly recommended!
    Thanks for the assistance Good Luck to all!
    • Ruze69's avatar
      Ruze69
