OrbiSupport99
Mar 19, 2026Aspirant
RBR50-V2.7.6.6 firmware install issues
I have repeatedly tried installing via both the mobile app and downloading the latest firmware directly from Orbi and ran into issues. When I try using the mobile app and ask it to check for upda...
CrimpOn
Mar 20, 2026Guru - Experienced User
Please check that firmware number again. The RBR50 is a "special case" among Orbi routers. A developer named Voxel created firmware for the 50 product quite some time ago and has been releasing updates (as recently as Sept 2025. His firmware begins with "9" so Orbi routers will look at any firmware release from Netgear and think, "oh. mine is newer." Voxel's most recent release was v9.2.5.2.42SF. https://www.voxel-firmware.com/Downloads/Voxel/html/orbi.html So, if your satellite has v9.2.7 that would not be from Voxel.
Was this satellite purchased separately from the router and other satellite?
The Forum has a mantra, "if it ain't broke, why fix it?" On the other hand, it is a very good idea to have all units of an Orbi system on the same firmware.
