radamo's avatar
radamo
Apprentice
Nov 26, 2025
RBR50 which is now needing to be rebooted almost daily
I also have an RBR50 which is now needing to be rebooted almost daily. Latest firmware is installed. Version V2.7.5.6. Getting pretty frustrated as it keeps disconnected from my HUE hub and I lose control of home lighting.
1 Reply
  • FURRYe38's avatar
    How many devices are connected to the Orbi system in total?
    Using ISP detected DNS or custom DNS?
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
