cheadrick
Dec 17, 2021Initiate
RBR50 WiFi iPhone Privacy Warning
iPhone 8 iOS 15.1
iPhone 12 iOS 15.1
Orbi RBR50 router firmware V2.7.3.22 No new firmware available
Orbi RBS50 Satellite firmware V2.7.3.22 No new firmware available
Our iPhones are reporting a Privacy Warning with our Orbi Mesh WiFi network.
The message on the iPhone is:
Privacy Warning
This network is blocking encrypted DNS traffic.
The names of the websites and other servers your device accesses on this network may be monitored and recorded by other devices on this network.
Does the Orbi Mesh network support encrypted DNS traffic?
How can this Privacy Warning be resolved?
apple is great at sending people warnings when they're not on the "latest" technology.
I haven't ran into the issue because I don't use apple products but you can try using a different dns server.
Try googles at 8.8.8.8 or 8.8.4.4
Or cloudfare's at 1.1.1.1
- steffgerAspirant
me too
This article goes into a lot of detail about this new iPhone "feature":
https://www.iphonetricks.org/how-to-fix-wifi-privacy-warning-on-iphone/
I particularly enjoyed the idea that using the regular unencrypted DNS would allow:
This means that other devices on the same network might track your browsing activity.
(updating router firmware will not accomplish anything on the Orbi platform.)
- ChickenlipsAspirant
Has there been any response from Orbi about this? Is it something that can be addressed?
- steffgerAspirantNo reply
This is mostly a Apple issue. Since Apple implemented this Wifi Privacy Address feature, this seems to be the main cause of it.
It's recommended, if your not travelling afar from home, disable this feature on your Apple devices as the random chaning of the devices MAC addresss really isn't needed while your at home or local work environment. IF you are travelling, then of course, have this feature enabled.https://www.iphonetricks.org/how-to-fix-wifi-privacy-warning-on-iphone/
Something that Apple should be asked about since this is there feature they came up with.
