nksaran's avatar
nksaran
RBR50 wired slow speed
I have 50 Mbps download speed and 10Mbps upload speed internet connection. When I connect my desktop directly to the modem, I am getting 50Mbps down and 10Mbps up. When I connect my orbi to modem and connect my desktop to orbi (wired), I am getting 2Mbps download and 10Mbps upload. I tried restarting the router, satalite and etc but no luck. WIFI speed is also 2Mbps down and 10Mbps upload.
Followingis the firmware I have in my Router and Satelite:
RBR50 - V2.5.2.4
RBS50 - V2.5.2.4
Have anyone faced this similar issue and know how to resolve it? Thanks.
  • Also the router reboots randomly 2 to 3 times a day on its own.
    RBR50 - V2.5.2.4
    RBS50 - V2.5.2.4
  • FURRYe38's avatar
    Did this happen before you updated to v4?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    ALso there is more recent FW version avail on NGs manual download site:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-Version-2-6-1-40/m-p/1997895/highlight/true#M105941
    Hasn't been posted to the auto up date servers as of yet...
    • nksaran's avatar
      nksaran
      Thanks. It did not happen before v4 firmware update but also this did not happen as soon as I updated firmware v4.
      Modem Mfr: Arris, Model: CM8200A
      Size of the home is 3300 Sq Ft. Router is in the 2nd floor and one satalite in 1st floor and one satelite in the basement.
      I disabled all the features that you had mentioned and restarted the router and Satelites, it did not improve.
      I also followed the config sugestion that was mentioned in the link that you had provided (https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026), but it did not improve either.
      I am going to factory reset and see it solves the problem.
      • FURRYe38's avatar
        Ok, I was going to mention powering OFF for 1 minute then back ON to see if this changes anything...Keep us posted.
