JasonMor's avatar
JasonMor
RBR50 with RBS50 forcing device to stay attached to specific Network Device
I haven't been able to find this anywhere so if this has been explained before I apologize.
I have an RBR50 (router mode) on my first floor and a RBS50 on my second floor. I have a device that doesn't move on my first floor which I'm having wifi issues with. I'm trying to troubleshoot the device but one of the suggestions was to see if there was a way to specifiy which Orbi Device it connects to. Can I force devices to only connect to the RBR50 or RBS50?
RBR50 and RBS50 Firmware 2.5.1.8
  • CrimpOn's avatar
    CrimpOn
    No, you cannot.  This is a function of the device comparing the two access points and selecting which one it will use.
    What you can do is attempt to influence the device by manipulating the radio strength and by resetting the device.
    For example, if the device is "closer to" the satellite, but remains connected to the router, perhaps it connected to the router when the Orbi first powered up and had "quit looking" by the time the satellite began transmitting.  Powering off the device and restarting when both the router and satellite are both working may cause it to prefer the satellite.
    You can try reducing the Transmit Power on one or both radio bands and restart the device.  If there is significant overlap in the radio coverage, this may affect which one it chooses.
    The key factor is "Is the device working correctly?"  If so, it may be a waste of time and effort to change its behavior.
  • FURRYe38's avatar
    You can lower the power output of the RBR from 100% to say 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
    • JasonMor's avatar
      JasonMor
      I haven't tried the signal strength idea yet but thank you for the suggestion. The device I'm trying to troubleshoot is approx 30 ft away from the rbr and 50 away from the rbs.
      The distance from the rbr or the rbs is approx 30 ft. They are on two different floors but above /below each other.
      • FURRYe38's avatar
        This should help some...let us know.
