SteveLivingston's avatar
Feb 18, 2022
RBR50 won't reset or boot
Hi - my 2yrs 2 month old rbr50 seems to have died (which feels early for what was meant to be a premium bit of kit when I bought it).
It was working fine with the only day 2 day issue being a Win10 laptop which used to get given invalid ip address relatively often. I blamed this on the quality of the work laptop...
Then I needed to enable portforwarding. When I tried to access 192.168.1.1 (or the website equivalent) it would ask for the login details... Then the screen would just remain blank. I then used the orbi mobile app to check if firmware needed updating (it did not). Then I used the orbi mobile app to tell it to reboot.
It never recovered from that reboot.
- The power led goes green.
- No WiFi network shows for any of my devices
- reset pin hole button does nothing (whether held down for 3/10/30 seconds before powering off/after powering off / before and after powering off etc) the power led just stays green throughout.
Any ideas of what else to try? Just seems fully bricked.
Is it possible to use a usb stick to force the reset?
