RoSk's avatar
RoSk
Follower
May 04, 2021
RBR50
I have a RBR50 Orbi Home Mesh system that works well downstairs but due to building material or whatever it is not strong enough upstairs (losing 90% speed).
Upstairs I do have a wall-mounted Power-over-Ethernet TP-Link Access point - it constantly drops despite all my efforts on Tx Power, Channel selection etc, and of course it is a separate and not meshed network.
So I would like to install a wall-mounted PoE Orbi Home mesh compliant access point instead (another satelite will not work as it must be Power over Ethernet).
Can someone be so kind so point me towards the right product ?
1 Reply
  • plemans's avatar
    There isn't an Orbi POE rated access point for the consumer equipment.
    the only Orbi one I know is the SRC60 which is the orbi pro. They don't mix between consumer orbi and orbi pro versions.
