MichaelSasa
Aug 07, 2024Follower
RBR50
I received a new Virgin Hub 5 and My Orbi and satellite will not connect, I have reset and gone through it several times and always says not found. Is there a way to change to a new wifi network via the app I think this is the problem it is still trying to connect to my old work. Also is it best to have the Hub in Modem mode, which I have also tried but it will still not find the orbis
thanks
1 Reply
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of networkWhat firmware is loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
