RTracey's avatar
RTracey
Tutor
May 26, 2020
RBR50/RBS50 current firmware confusion
I'm having some issues with my wifi coverage and thought I would begin by confirming the firmware is up to date.  The RBR50 and RBS50 are at V2.3.5.30 and V2.5.1.8 respectively and both show "No new firmware version available". Yet on the Netgear website, it shows V2.5.1.16 as the latest firmware version for both router and satellite - which is newer for the router, and older for the satellite.  So what do I do?  Leave things alone?  Update the router and do nothing with the satellite?  Roll back the satellite and update the router?  Thanks.
  • 2.5.1.16 is newer than both 2.3 (anything) and 2.5.1.8 (16 bigger than 8).  The concensus appears to be that having router and satellite on the same version is a good practice.  So, the satellite should be updated to 2.5.1.8.  However, there are always risks when updating firmware.  Even if 99.5% of the time everything goes great, that 0.5% can cause problems ranging from puzzling behavior to horrible problems.
    If the system is doing everything you want, there is no urgency to touch it.  Getting the router and satellite on the same version is probably a good idea.
    Not much help. Sorry.
  • CrimpOn's avatar
    CrimpOn
  • FURRYe38's avatar
    If you have a need to update to v16, you can manually download the FW files:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    Update the RBS first then the RBR lastly. RBR and RBS should always be on the same version of FW.
    • RTracey's avatar
      RTracey
      Tutor
      Thanks both.  I updated the software on the satellite without issue.  The router however has been sitting on "The router is updating its firmware" for the past 30 min and showing no change in the progress bar, yet it says it should only take 3 min.  And I'm still connected to the internet via wifi, so what gives?  Should I log off from the router in my browser and log in again?  The instructions say don't reset the router directly.  Thanks.
      • CrimpOn's avatar
        CrimpOn
        That's what I would try.
