PimVersteeg
Dec 07, 2018Aspirant
RBR50/RBS50 different SSID
Hi,
I have just installed my RBR50 router in AP mode, everything seems to be working as expected. Have been able to change SSID to a different name, all my devices connected to the AP have inte...
- Dec 07, 2018
PimVersteeg wrote:
..............Tried to connect first satellite, have done so by putting it in the vincinity of the AP, afterwards I moved it to a different room with ethernet backhaul connection.
The browser login on the AP's SSID shows the satellite connected thru backhaul and it has an IP address.
However , it also broadcasts its own SSID (ORBI53) and the ios app sees the satellite not as "connected" to router in AP mode (purple)
It seems that you did not do the Satellite addition correctly. When you brought the Satellite in the vicinity of the Router, have you pressed the Sync button on both units to make them sync? Have you got the Satellite ring to light steady blue? If not, then please repeat this part before connecting them with Ethernet.
Dec 07, 2018Guru - Experienced User
What FW is currently loaded on the AP base and satellite?
Try a factory reset on the RBS and re-add it to the AP base.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
