musicman8120
Apr 08, 2023Aspirant
RBR50v.2 Using with a Cox Panoramic WiFi cable modem
We just purchased an Orbi RBR50v2 system and I have a question regarding using this with our Cox Panoramic WiFi modem. Can the network name and password set in the Cox box but used in the Orbi system...
Apr 08, 2023Guru - Experienced User
Would need to be different unless you want the Orbi to replace the ISP modems wifi signal and disable the ISP Modems wifi. Which would be recommended.
musicman8120
Thanks for the reply. My intention was to extend my Cox WiFi further without having to have a different network and causing devices to have to switch back and forth as they move locations. Perhaps this is the wrong system to do that ?
