eaquitas00's avatar
eaquitas00
Follower
Oct 21, 2022
RBR50V2 constantly dropping connections
I have 2 satellites on my system that I purchased in March 2020. About 3 or 4 months ago June/July 2022 the Satellites started starting signals from hard wired devices. We have a large home, and the satellites and the main units have been in the same spots for over a year since moving with no issues. I have tried everything I have read to fix the issue. Just some small examples of which are a full factory reset, tried putting everything on WiFi only no hardwire. Tried moving satellites closer and further away. Even tried just one satellite. And I tried all the different settings on my Orbi. The only partial fix I have found is shutting down both satellites. Then it only drops some devices from the system. I am very frustrated spending so much money on a system that only lasted a little over 2 years. We work from home so this is a need to have good internet. I am now in the process of getting a Nighthawk AX5400 with WiFi 6. Before getting the Orbi I always used Nighthawk routers so I am going back to that. I will keep the main Orbi as a backup but I don’t see I would waste that much money again on an Orbi. If someone else has any ideas on how to fix my Orbi issues I will try it and return my Nighthawk to Costco.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many devices do you have connected to the system?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970
  • plemans's avatar
    1. what modem/gateway is the router connected to?
    2. what actual firmware version are you on?
    3. have you tried reinstalling the firmware to the satellites/router and then doing a factory reset? If somethings corrupt, a reset only removes settings versus reinstalling the firmware might over write the corruption issue.
