Xx-Shadowz-xX
May 08, 2022Aspirant
RBR50v2 ROUTER FIRMWARE VERSION IS DIFFERENT THAN MY 2 RBS50v2 SATELLITES
I have 2 RBS50v2 Satellites that are running the latest firmware version 2.7.4.24 and both are connected wirelessly to my RBR50v2 Router which is running the firmware 2.7.3.22 that is before the lates...
CrimpOn
May 08, 2022Guru - Experienced User
There is always a vague uneasy feeling when router and satellites are not on the same firmware release. If you 'downgrade' the satellites manually to match the router, then eventually Netgear may 'auto-upgrade' everything to the current release on the support web site.
If you are going to all this effort, I would probably update the router (1 device) rather than the satellites (2 devices) and get it all over with.
Xx-Shadowz-xX
Ok I will do that then I’m have to probably do a manual update to the router since it doesn’t show there is a new update available whenever I access my router using the web UI. I was just concerned on what I should do exactly since lately I been seeing plenty of people having problems after recent update. I just wanted to make sure if I did update that I wouldn’t have to go through any issues at all
