joanba
Sep 10, 2025Tutor
RBR50v2 self-signed certificate rejected
Hi, I use an Orbi router RBR50v2 with 2 satellites and they work as expected. Problem is when I try to access the admin page, for example: https://orbilogin.net/index.htm Safari rejects i...
joanba
Sep 11, 2025Tutor
I've been able to use Chrome finally, first importing the router certificate as trusted and using the URL with hostname like https://orbilogin.net... With ip address I still get the error. I've swtiched off the option to access the router with HTTPS only in RBR50, and Safari is able to arrive to login screen now with the ip address. But after login, I'm redirected to https:// so error again in Safari. I've a router restart pending to see if the 'access router with HTTPS only' option requires it.
