Orbirbr53user's avatar
Apr 26, 2020
RBR53 what satelite
I have the Orbi RBR53, so that’s one Router RBR50 with 2 satelites. I do not get the necessary coverage with the existing setup.
What compatible satelites could I add to my setup?
  • I have the RBR53 system and the satellites are model RBS50, so you can get more of them.
    • Orbirbr53user's avatar
      Orbirbr53user
      I cannot easily find one on sale. The cheapest I could find it is £194 which I think is a very steap price to pay for a satelite. The whole system cost me £300 and even that I think is overpriced given that a router and 2 satelites cannot cover my regular 3-bed UK semi-detached house.
      • FURRYe38's avatar
  • FURRYe38's avatar
      Orbirbr53user
      I am based in the UK and live in a normal semi-detached 3-bed 1930s 2-storey house, around 140sq meters, all in. I do not think that I have an issue with the location of the satelites, one of them is in the middle of the hallway and yet my wifi calls drop when I am in one corner of the house and on the same floor. I have tried different Advanced settings such as Mimo, Beamforming, Fast Roaming, to no avail. If I move the satelite even closer to my study then I lose wifi reception when I go to the kitchen to make a tea while on a call. I have given up on making my setup any better, all I am trying to find out if I could use a different make/model of a wifi extender given that the recommended satelites are too expensive and difficult to find.
      The whole point of a mesh system is that you are supposed to be able to add satelites to it on need basis. In fact, you need to ensure that you get the right size to start with. A lot of people in forums were recommending that I get just one satelite for the (small) size of my house but I thought lets play it safe and get 2. Not sufficient but that is not the point of my post.
