boston_mama
Aug 25, 2021Guide
RBR750 keeps going offline
My Orbi RBR750 (model + 2 satellites) keeps going offline. It's fine at night but in the morning will be offline. I reboot it using the app and it's fine but it's going offline several times a week...
Aug 25, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
boston_mama
Aug 25, 2021Guide
Thank you for the suggestion. I reposted over there.
- FURRYe38Aug 25, 2021Guru - Experienced User
