boston_mama
Aug 25, 2021Guide
orbi rbr750 keeps going offline overnight
My Orbi RBR750 (model + 2 satellites) keeps going offline. It's fine at night but in the morning will be offline. I reboot it using the app and it's fine but it's going offline several times a week. No action needed on my modem from xfinity, I just need to reboot the orbi. From what I can tell, my firmware is up to date (V4.6.3.7). It's 4 months old.
Can someone help me understand what to do?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Do you see any front LED colors on the RBR or RBS when this happens?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡My answers below:
It's hooked up to an xfinity gateway -
Voice and Data Modem
ARRIS Group, Inc. TG4482A
Yes
No color on the RBS. Not sure on the RBR. I'd have to look at this next time.
2500 sq feet
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Yes
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
