DrBen
Aug 12, 2021Follower
rbr750 network password chaange
RBK750 Orbi
I would like to change the network password without changing it on every connected deice. Is that possible?
No. if you change the password to access the network, then all those connected devices need to have theirs changed as well so they can access it.
> every connected deice. Is that possible?Why? Is there some actual problem which you are trying to solve?
Sure you can, _if_ you change it (on the router) to what every
connected device is using. You can't make a change on the router which
will also make a similar change on every connected device.
