SRM-55
Mar 01, 2019Aspirant
RBRK50 and wired home network
In new house, cat6 ethernet patch panel (unlabled) is wired to several (unlabled) ethernet ports throughout home. I set up a Spectrum Internet modem (non-wifi model), added Orbi router and satellite...
Mar 01, 2019Guru - Experienced User
If the LAN port on the back of the Orbi works with a direct connection, then the LAN ports on the Orbi are working. This is not a Orbi issue. You need to check the connections from the patch panel to the remote locations to see if the LAN cabling in between the patch panel and the remote room jack are correct and in good working order.
Hook up one cable from the orbi to one of the jacks on the patch panel. Using a wired laptop, you'll need to go from room to room to see if you can find which room as the internet access when you connect the laptop to the jack in that room. If you still don't get any access, try a different jack on the patch panel. Possilble bad cabling to concider as well. Make sure your patch LAN cable is in good working order as well from the Orbi to the patch panel and from the Laptop to the room jack.
SRM-55 wrote:
In new house, cat6 ethernet patch panel (unlabled) is wired to several (unlabled) ethernet ports throughout home. I set up a Spectrum Internet modem (non-wifi model), added Orbi router and satellite. Wired connection directly to Spectrum modem works. Wired connection through LAN port on Orbi router works. Wifi connection to Orbi system also works. When I use one of the LAN ports on the Orbi router (not satellite) to connect to any of ports in the Cat 6 patch panel (yes, I checked to make sure they were wires punched down into the patch panel), I can't get an wired ethenet connection on my laptop in any wired ethernet port in the house. I get the "no internet connection" page on my browser. Have tried all the ports on the patch panel, in numerous locations around the home. So it SEEMS to me that the link that isn't working is the one from the Orbi router LAN port to the patch panel. The previous owners had their TV's setup to have wired ethernet connections, so I think I should be able to do the same. Do I need to make any changes in the Orbi router software to allow the Orbi router to serve as the main gateway for the wired ethernet in the home?
- SRM-55Mar 01, 2019Aspirant
Yes - I’m think checking all the cable is a good start. I’m using brand new cables from the Orbi router to the patch panel. All the wiring in the walls is only 2-3 years old but I’m using an old cable to go from wall port to the laptop so that could be part of it - although it seems to work when directly connected to the Orbi, it did seem really slow so maybe that is at least part of it....thanks!
- FURRYe38Mar 02, 2019Guru - Experienced User
Ya this may be a pain however if you can get ALL the cables figures out and rooms tied to whats on the Panel, I would set up a lable system, something simple. I just use numbers 1-10 or ever how many rooms you have. Write down the numbers then lable each one with what room it's tied to. What I have done for my patch panel.
At somepoint, you'll want to get a Un-managed 1Gb network switch installed. Connect the patch panel cabling to this switch, then all you need is just 1 LAN cable going from this switch to the back of the orbi router. Then ALL rooms will have internet access at there jacks. I use a 24port with my patch panel. Room for growth if needed.
Let us know how it goes. Use good quality CAT6 cabling and patch cables.
