SRM-55
Mar 01, 2019Aspirant
RBRK50 and wired home network
In new house, cat6 ethernet patch panel (unlabled) is wired to several (unlabled) ethernet ports throughout home. I set up a Spectrum Internet modem (non-wifi model), added Orbi router and satellite...
ekhalil
Mar 01, 2019Master
SRM-55 wrote:
.............. So it SEEMS to me that the link that isn't working is the one from the Orbi router LAN port to the patch panel.
What type of switch do you have at the patch panel?
- SRM-55Mar 01, 2019Aspirant
There isn’t a switch between the Orbi router and the patch panel, at the moment.
- RocketSquirrelMar 01, 2019Luminary
The first thing that occurs to me is that the previous owners took a switch or two with them when they moved, leaving you with gaps in your LAN cabling.
- SRM-55Mar 02, 2019Aspirant
Yeah, I realize I may need to add a switch but just trying to do this step by step first!, thanks!
