pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
PCSP
Jul 31, 2021Guide
Enable telnet in Debug mode is missing
- PCSPAug 04, 2021Guide
@FURRYe38 wrote: https://community.netgear.com/t5/Orbi/RBS50-issues-with-Firware-V2-7-3-22-Firmware-incorrect/td-p/2113523/jump-to/first-unread-message @PCSP wrote: Enable telnet in Debug mode is missing
I think I use correct version (I downloaded 10 July 2021 - and got RBR50-V2.7.3.22.img, RBS50-V2.7.3.22.img) and everything is OK except missing enable telnet in Debug mode.
I will try download it again and test it
$ md5sum *V2.7.3.22*
09a78255fb2ce64d065eb59805ca3750 RBR50-V2.7.3.22-20210710.zip
09a78255fb2ce64d065eb59805ca3750 RBR50-V2.7.3.22-20210805.zip
ad86562c89a82678e366bb28fdec218b RBS50-V2.7.3.22-20210710.zip
ad86562c89a82678e366bb28fdec218b RBS50-V2.7.3.22-20210805.zip- FURRYe38Aug 05, 2021Guru - Experienced User
Telnet is no longer supported on NG FW.
PCSP wrote:@FURRYe38 wrote: https://community.netgear.com/t5/Orbi/RBS50-issues-with-Firware-V2-7-3-22-Firmware-incorrect/td-p/2113523/jump-to/first-unread-message @PCSP wrote: Enable telnet in Debug mode is missing
ad86562c89a82678e366bb28fdec218b RBS50-V2.7.3.22-20210805.zip- GeblaAug 05, 2021ApprenticeThis release is broken as well. Wired devices to a hub loose connection for a short period of time. Short drop outd causing streams to break/stop.
When is Netgear able to create a release without problem. This is ridiculous.
Tried a reset and still issue occurs.
