sandman512's avatar
sandman512
Apprentice
Jan 14, 2021
RBS 50 Satellite, running different firware versions.
So, currently running a RBR50 with THREE RBS satellites(all wired in).  Just noticed that TWO satellites are running firmware version V2.5.2.4 and one is running V2.7.2.102.  I checked for updates and there were none.  Any thoughts on this?  Thank you and be well!
  • CrimpOn's avatar
    CrimpOn
    What firmware version is the router running?
    • sandman512's avatar
      sandman512
      Apprentice
      Thanks for the reply.  So, I attempted to manually perform the update.   On of the satellites updated to the latest(V2.7.2.102). and the other didn't.  FWIW, the router is running Router Firmware Version
      V2.5.2.4.
      Thank you!
      • FURRYe38's avatar
        FWIW, RBR and RBS have to use same version of FW. So you need to either downgrade the RBS to what the RBR is using or update the RBR to what the RBS are using.
        V2.5.2.4.
        Thank you!
