LandoSan
Apr 06, 2026Aspirant
RBS20 bricked? red power led flashing
had an old pair of RBS20 satellites with red power led flashing won´t connect to router removed them bricked? searched a lot what worked for me removed satellites from router updated router t...
- Apr 07, 2026
According to FURRYe38 suggested... marking it as solved...
solution built with info collected in several different posts, and some guesswork...
Apr 06, 2026Guru - Experienced User
Glad you got it working. Thank you for sharing the details. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
