RFrosty
Mar 06, 2025Follower
RBS20 Satellite power LED flashing red
One of my RBS20 satellites has a red flashing power light and refuses to connect to the router.
The router and other satellite are fine. I’m unaware of any changes overnight.
I’ve attempted several factory resets but the device does not change in any way when the reset is pressed/held
The old off/on doesn’t work
Rebooting the router doesn’t work
The satellite does not respond to the sync button either
Any ideas?
Any ideas?
1 Reply
Try a 30-30-30 reset process on the RBS.
IF this fails, then the RBS may have gone bad.
