defjab2's avatar
defjab2
Follower
Sep 21, 2023
RBS20/RBR20 Firmware
I haven't seen an update since December - is netgear no longer addressing active threats as I see other models getting fairly frequent (security) updates ? I did confirm that products are NOT EOL
1 Reply
  • FURRYe38's avatar
    And?
    Are you having problems with your system?
    Usually if there are not issues at hand, NG doesn't release any FW updates.
    Also may take months and months for new FW to appear. Especially as the model series ages, FW updates don't releases as frequently.
