Dckl
Jun 04, 2020Follower
Rbs40 cat5e or cat6
Assuming I use cat 6 through out to plug into the main unit doesn’t make sense it use and get a benefit of using cat 6 Ethernet cables from the satellite unit RBS40 or no difference in performance wit...
Jun 04, 2020Guru - Experienced User
CAT6 has better performance over 5e. CAT6 and dont mix CAT versions.
