spacebar
Jul 27, 2018Aspirant
rbs40 manual firmware update
So, I have already contacted Amazon and got a new system coming but in the meantime I wanna see if I can resolve this issue. Like many before me, I am sure, the RBS40 is just flashing a white light t...
Jul 27, 2018Guru - Experienced User
Yes you can download the FW files and if you have the satellite connected to the router base, upgrade that first, then upgrade the router with a LAN cable connected PC. Then I would do a full factory reset on the both router and satellite then setup from scratch.
Heres how I got my friends 50 series up and running:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020
spacebar
quick update...
I followed another post in this community. I am a mac user and had to use mac software versions of all the windows software but the solution worked and it seems that the system is working once again as advertised. If it stops working again I will follow these recommendations by FURRYe38 and try that. The ones I followed were by lightmaster https://community.netgear.com/t5/Orbi/Solution-to-fix-Orbi-Satellite-flashing-white-forever-failed/m-p/1588079#M33357
I am wondering now if I should contact Amazon and tell them not to send the replacement.
anyway good source of info on this forum
Funny Fact: i was talking to a netgear person on the phone for over an hour trying to resolve this issue not including the hold time. their suggestion was to replace the items
