numzie77
Apr 05, 2020Guide
RBS40 satellite - will this power plug work
Hi
I accidently broke one of the legs on the EU power plug for my Satellite - so now I'm looking for a replacement (the one I had was also a replacement as I bought the Orbi set second hand). It had a Ktec KSAS0361200250HE adaptor.
I found this one - actually very close to me - but I'm not sure if it will work for me?
It seems to be 12V > 2.5a with the right size pin, so I hope someone can confirm this will work for my Satellite:
Best,
Kenneth
You might contact the seller of the adapter to see if it will work for your RBS. I believe it should.
Just make sure the voltage and amps match the original power adapter values.
