Gjarrett
Jan 06, 2019Aspirant
Rbs40 wired backhaul on a rbk50? Just as extra range....
I have an rbk50 system all working fine.
the rbr50 and rbs50 are wired together.
the question is I found a great deal on a rbk40, I know I can’t add the rbr40 but can I add the rbs40 “wired” for ...
ekhalil
Jan 06, 2019Master
Gjarrett wrote:
.... would there be any overall network performance issues?
You should be fine, it's just that the backhaul of the RBS40 will be limited to 867 Mbps (wireless) :)
The backhaul of an RBS50 if wirelessly connected to RBR50 is 1.7 Gbps and much more if wired as you currently have it!
Good luck.
