Gjarrett
Jan 06, 2019Aspirant
Rbs40 wired backhaul on a rbk50? Just as extra range....
I have an rbk50 system all working fine.
the rbr50 and rbs50 are wired together.
the question is I found a great deal on a rbk40, I know I can’t add the rbr40 but can I add the rbs40 “wired” for ...
Jan 06, 2019Guru - Experienced User
RBR can only work as main host routers or main AP mode. I presume you can connect them togther however the two will have separate wifi SSIDs and will not sync together as RBS will. I would configure the RBR for AP mode then connect it if you choose to get another.
the question is I found a great deal on a rbk40, I know I can’t add the rbr40 but can I add the rbs40 “wired” for a extra satellite?
I know the rbs40 is slower.... would there be any overall network performance issues?
- GjarrettJan 06, 2019Aspirant
I wasn’t plannng on using the rbr just the rbs?
