rdun72
Oct 03, 2018Tutor
RBS40 with 2.2.1.210 firmware!
Hi,
Just bought an RBS40 from Amazon (like new) to extend my existing system which consists of an RBR40 and another RBS40 (both running 2.1.4.16, wired backhaul, stable). Plugged new RBS40 into...
- Oct 03, 2018
Thanks very much for the reply. I solved it. Basically I got unlucky that there was a push of new software as I was trying to upgrade the new RBS40 I bought. So the solution was to manually upgrade the new RBS40 from v1.0.x to v2.0.x which got me around its complaint about the 2.1.4 firmware image. From there everything automatically updated to 2.2.1.210. All running ok so far with ethernet backhaul but let's see for a few days....
rdun72
Oct 03, 2018Tutor
Oct 03, 2018Guru - Experienced User
Ok sounds good. Keep us posted. :smileywink:
