PB21UK's avatar
PB21UK
Tutor
Mar 25, 2019
RBS40V latest firmware RBS40V-V2.3.0.10_1.0.1 update failure
Has anyone tried the latest update, I cant update with this file in auto  update online mode or manually I am at version 08 at present.
  • PB21UK's avatar
    PB21UK
    Mar 26, 2019
    Finally, it went through but showed as failed, I tried a second time and then it succeeded. I updated via the web interface on the router and selected the satellite voice as the one to update but manually. The auto update kept failing.
    • michaelkenward's avatar
      michaelkenward
      I completed the update to V2.3.0.10_1.0.1 yesterday.
      I just followed the usual strategy.
      What happens when you try, and where does it go wrong?
      RBS40V Firmware Version 2.3.0.10 | Answer | NETGEAR Support
      What Orbi router do you have?
      Are you starting the update from the router or from the satellite's graphical user interface (GUI)?
      • PB21UK's avatar
        PB21UK
        Tutor
