Jgoldsti's avatar
Nov 16, 2020
Rbs40v showing region japan while rbr50 router is showing region north america
I have an Rbs40v, running 2.6.1.4 firmware, connected to an rbr50, running firmware 2.7.1.60. The rbr50 (and my rbs50) correctly showing region as North America,
the Rbs40v shows region as Japan.
I have factory reset the rbs40v twice and region still shows as Japan.
in addition Rbs40v will only connect to rbr50 using 2.4g.
I have tried putting the Rbs40v next to the rbr50 and syncing them...will not connect via 5g.
I have tried downgrading rbr50 firmware to 26.1.40 and still have the same problems
  • I reuturned the unit to Amazon and got anew unit.
    new unit works perfectly.
    • Jgoldsti's avatar
      Jgoldsti
      Star
